    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
WalterG7712
Looking for service manual or at least help with icemaker. Intermittent problem of not making ice, or dispensing water
  • Replies 6
  • WalterG7712
  • john63
  • Strathy
Also there ... check downloads section.
  • Like 2
Two issues with this model...
1) Serial Numbers ranging from 103KRxxx through 111KRxxx---water line inside door is too close to the icemaker cooling ducts (frozen).
Not a repairable fault. Replace entire door assy.
2) Serial Numbers 311KRxxx and earlier/lower---Prone to "ER/IF" error and fan blade noise (hitting ice/heavy frost). Icemaker intermittently functions.
Replace the GrilleFan Assy (AEB73785610). An internal heater has been installed around the "ice room" fan motor to eliminate ice/frost interference.
WalterG7712
Search in downloads came back "no results found"
Walk this way...
WalterG7712
Serial is 104kr.... Customer says they will buy bagged ice for awhile.
Thanks for the help.
Your welcome:)
A note of caution---should your customer change their mind (or you encounter a similar refrigerator)...
Before removing or installing a door---it must be opened at a 90 degree angle.
Removing or installing the door at the 90 degree angle---allows for correct internal door tension spring and cam position.
An improperly installed door---will not close correctly.
More than a few retailer delivery/installation crews have made this mistake.
A quick fix---would be to carry the Lower Door Hinge (and use as a tool)
When correcting/repairing an improperly installed door (especially the left side with all of the wiring and water line hook-ups)
the top hinge can be disconnected/loose
Without disconnecting the wiring or water line---the door can be lifted off the lower hinge---insert the *hinge tool* and rotate
the spring within the door to the correct position.
Position the door at a 90 degree angle and re-install door/re-install the upper hinge. Done.
Edited by john63
