I need the tech sheet for this dryer.  The unit times down to one minute and continues to run while not heating and won't shut off.  It doesn't matter if it's set on timed or sensor dry or if the wrinkle guard setting is on or off.  I've replaced the main control already and it still has this issue.  I would like to run diagnostics but of course the tech sheet is no where to be found.   I did find the troubleshooting tech sheet in these forums, but it does not tell how to run the diagnostics.
Edited by ROBBYRIG
The Fast Track manual is already in the Downloads section.  Search using the technique shown below:
I found that manual oh Great One and have printed it off and read it several times.  However it does not address the issue I am experiencing.
This forum is for service manual requests only.  Please post your technical questions on this dryer in the Laundry forum.  Thank you, come again!
