May I have a service manual for this 3 year dryer
Patricio. What did you find when you did your searches? Many cabrio dryer manual/tech sheets pull up. Did you check to see if any of those are compatable?
WED6200* brought up no results. I am mainly interested in opening it up.
OK found what I was looking for in laundry section under title whirlpool cabrio over heats using my android. Thanks justin
If you search for wed* many models pull up. yoi can then find a comparable manual. One of them is compatable. Also remember WL May research. The manual IS in there. I looked.
