    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
kitchenaid mixer mod ksm5pswd..ksm5pso
First time on one of these. Got it going.. replaced snubber board, brushes and switch plate.
Question is on parts. snubber board
.two were given on Appliance part pro. I went with W10325124 30.95
other part num w10538289. much cheaper 7.12... whats the difference.
also found part num 9706595 cheap.
thanks for any info.
  • 1 year later...
  • Replies 1
  • curjones
  • nolazach
nothing, nothing at all I don't think.  1st source had them cheap.  I think $7, I bought a few of them because 9/10 times the tilt top mixers have a bad phase board (snubber I guess?) or bad brushes. The brushes are cheap at servall as well.
   I have been fixing 4-5 mixers a week.  A lot of commercial ones from small shops, even did one for John Besh, my first celebrity chef customer.  Though I only met his assistant, bummer.
     A lot of money in repairing these for as cheap as parts are.   I only charge $45 to look at them, then just wing the rest, but it's so easy.  The professional models are the best, the whole gear and motor assembly is one $85 part, you charge whatever.  It takes five minutes to swap.   The ones like you have are my least favorite to do gear work on because of all the roll pins.
    Whenever I change a phase board I always change the speed control as well, just because both parts are so cheap.  (Whirlpool parts to boot)
  I really like working on them.  In fact this Christmas I'm giving a few away because I keep buying up all the broken ones for under $80 I can find.
