Samsung refrigerator rf261beaebc/aa
johntech
Service Manual
RF260BEAEBC/AA / RF260BEAESP/AA / RF260BEAESR/AA / RF260BEAEWW/AA / RF261BEAEBC/AA / RF261BEAESP/AA / RF261BEAESR/AA / RF261BEAEWW/AA / RF26HFPNBSR/AA
Training Manual
Service Pointers
ASC20130507001
RF220NCTABC/AA / RF220NCTASP/AA / RF220NCTASR/AA / RF220NCTAWW/AA / RF221NCTABC/AA / RF221NCTASP/AA / RF221NCTASR/AA / RF221NCTAWW/AA / RF260BEAEBC/AA / RF260BEAESP/AA / RF260BEAESR/AA / RF260BEAEWW/AA / RF261BEAEBC/AA / RF261BEAESP/AA / RF261BEAESR/AA / RF261BEAEWW/AA / RF263BEAEBC/AA / RF263BEAESP/AA / RF263BEAESR/AA / RF263BEAEWW/AA / RF263TEAEBC/AA / RF263TEAESP/AA / RF263TEAESR/AA / RF263TEAEWW/AA
SUBJECT
 Fresh Food section shelves out of alignment
 Symptom:          Shelves tilt at the center and may not line up correctly.
Background:    In production, the wrong size screw (30mm) was used to attach the
                          Evaporator cover and shelf support ladder.  This screw must be 35mm long.
Factory Solution:      The error was identified and corrected beginning with March, 2013 production.  The correct screw is now used on all models.
Field Solution:           Replace the incorrect screw with a 35mm (1.37 in) stainless steel screw.
Part Needed:           6002-001432             SCREW
ASC20121115001
RF260BEAEBC/AA / RF260BEAESP/AA / RF260BEAESR/AA / RF260BEAEWW/AA / RF261BEAEBC/AA / RF261BEAESP/AA / RF261BEAESR/AA / RF261BEAEWW/AA / RF263BEAEBC/AA / RF263BEAESP/AA / RF263BEAESR/AA / RF263BEAEWW/AA / RF263TEAEBC/AA / RF263TEAESP/AA / RF263TEAESR/AA / RF263TEAEWW/AA / RF323TEDBBC/AA / RF323TEDBSR/AA / RF323TEDBWW/AA
Symptom:When the left refrigerator section door is closed, the flap does not close properly, creating a gap and air leakage.
Background: The door flap is too low on the door. The spring-loaded tab at the top of the flap does not meet the cabinet actuator.
Solution: Please see the attached PDF file.
ASC20120905001
Subject:  The Auto Pullout Feature for the UpperFreezer Drawer does not work correctly.
Background: The stops on the lower drawer are missing, so the upper tray will not roll out automatically.
Solution: Replace the lower freezer drawer.  All new drawers include the stops.
