applianceman1
This is a GE Profile Downdraft Cooktop.
I'm looking for the tech sheet or service manual
for this cooktop.
Walter, that model number is incomplete-- there should be a number after the "N."
applianceman1
I'll have to check with the customer.
He said the right front burner was
only heating in the middle.
It's a glass top with down draft.
If I can't get the number are they all
disassembled the same.
All the GE glasstops I've worked on have about a dozen Torx screws around the perimeter that allow you to take the glass off. The tech sheet should be inside. Two main possibilities are the burner itself, in which case the burn will be obvious and the infinite control. Pretty straight forward, either way.
applianceman1
Thanks for the information.
I tried to get the tech sheet in the
downloads but there isn't one.
Like you said pretty straight forward.
  • 2 weeks later...
applianceman1
Yes it was the burner.
As it turned out a pretty easy job.
Thanks for your help.
Great job! Thanks for the update!
