To the Dojo,
Do send the KM (LG) FRIDGE 795.79299902 manual, please.
Thanks in advance,
Red
here ya go bro Ty.. created just for you
http://appliantology.org/files/file/2071-lgkenmoretmservicemanual/
btw when searching for models where there is a decimal point, try a search string without a decimal but using * before and after a few digits that come after the decimal.... for instance if you searched for *79299* prior to my uploading this file, you would have found the following thread http://appliantology.org/topic/44172-kenmore79579299901lg-refrigerator-servcie-manual-request/?hl=%2A79299%2A. In there you will see a possible compatible manual.
Two points to take from this info
1) decimal points confuses the search engine and
2) don't forget to search the forums for threads requesting your manual as that thread may point to a manual which will not come up in the dl section if you use the same search string that found the thread.
Hopes this helps!
Edited by DurhamAppliance
  • Like 3
Many thanks to you, my Tarheel appliantological brother!
