Maytag coin op dryer model: mdg22pdaww0 serial:my3301169 type: dhlv-nat-1206006-el24
Fisherking1979
Fisherking1979
In need of repair manual, I replaced the pcb due to it having a burn mark on it. It synced when installed then I hit a button and changed a setting, now it only works when $4.25 in put in. Need to change it back to $.25 per 5 minutes. Please help
Edited by Fisherking1979
  • Replies 1
  • Fisherking1979
