GE Monogram Freezer ZIFS36NMILH Service Manual
mcathcart
Been working on a GE Monogram Freezer for 2 days now.   2006 mfg.  The first call, "My Freezer Is Not Cold".   Going to the house, I found several things.
Top of Freezer 48 degrees (bottom) 32 degrees.
1. The Evaporator Fan Motor seem to be intermittent.
2. The Door Seal does not seem very strong. Possible leak at top.  (The H.O. says the Freezer normally "Sucks" the door Closed?  Can't figure that one out.) Currently it's Not Sucking the Door Closed (even when pushing on it).
3. Defrost Heater is drawing 2.7 amps (and evaporator looks to be free of ice but the Front cover was Iced Up).  Pulled the lower draws and used a heat gun to remove ice.
4.  Very little Air coming from Evaporator Fan.
The first day I replaced the Defrost Timer Hoping that it was the problem.  Today going back it's not any better. Temps about the same. The defrost timer Red & Black wires go to compressor,  Yellow wire was drawing 2.7 amps in defrost and Orange zero.
I cleaned both sides of the evaporator(s) yesterday.  The compressor high side line is Hot to the Touch (which makes me think the charge is OK).   The suction line is about ambient temp 70 degrees.  Condenser temp is also about ambient.
The kicker is the Wiring Diagram is MISSING!   I have not been able to locate one.   Is the Evaporator Fan connected directly to the Left Door Switch (or does it go through a temp sensor)?
Any Help Would Be Appreciated!  I searched before posting for the Service Manual and shortened the Model Number hoping for a Hit on something close but no luck.
  • Replies 5
  • mcathcart
  • DurhamAppliance
Per posted instructions, (see http://appliantology.org/topic/49629-manual-request-topic-title-must-include-manufacturer-type-of-appliance-and-model/) this forum is for service manual requests ONLY.... ANY repair question must be posted in the appropriate forum.
Edited by DurhamAppliance
I Used the SEARCH and Did Not Locate Anything.
Sorry if I Asked a Question.  (Didn't see any Edit to remove the other.)
I NEED A SERVICE MANUAL or ELECTRICAL DIAGRAM.
While that search is underway, it would be prudent to seek advice in the kitchen forum.
