Maytag Comercial dryer mod. # mde22praywo
I installed new control board mounted on the front of the unit. This is not coin operated. After installing pcb I got an D5 error code. I found a tech sheet on this sight and it said it was coin related, but this unit does not take coins. Does anyone have an answer??
If you have the tech sheet follow the instructions on programing (on page 4)  and go to code d and it needs to be set to d00 (on page 6) which means there is no coin slot installed.
thank mr spannerwrench I will try this tomorrow.
