Any one can point me to a Service Manual for information on this hybrid water heater that uses refrigeration to heat the water?   This vacation home has a bank of three of these things for a vacation home.   One of them has quit working.   Sure keeps the garage cold in the summer where they are located.
Thank you Budget, just the ticket.   That big GE manual stash, is it located in the download section?    I searched the download & forun section using different search terms & could not find anything.   I found else on google is the F-C code is a problem with these WH's  where the factory is changing out evaps & dryers.
It's not in the download section here, there is a link to the large GE manual stash somewhere around here.
I did a search on "Mabe*" which I know is in the website name and found it:
Gold mine of GE tech sheets
http://appliantology.org/topic/48177-gold-mine-of-ge-tech-sheets
This might help you more - a complete directory of training and info on just this hybrid water heater
http://applianceservice.mabe.ca/learning/waterheater/
