KUDE48FXSS5.  I need a service manual.
normal wash and heat dry are flashingeven after replacing main board.  It works once the stops mid cycle. It will work agin after reset but stops again.
Did you search the download section prior to requesting (Please read the notices located on the main page of the Manual Request forum)?
If you searched but was unsuccessful, check out http://appliantology.org/topic/51337-getting-started-at-appliantology/making sure to watch the video on searching for documents.
Let us know if you still have problems locating the info.
Edited by DurhamAppliance
I did search first.  I can try again
What search string did you use?
I got it.  I used the first few digits with an astrix.  My exact model did not come up, but what I got was for the right series.  Thanks
  • Like 2
Great Job!
