I could not locate this manual in the download section. The customer's complaint is the santize light does not illuminate at the end of the cycle. I need a manual to see when the light should illuminate. Thank you.
  • jlb813
Thank you. I can't find a service manual that lists this model but I do see one that lists the "WDF530" so it is probably pretty close. Hopefully, the tech sheet is on the unit anyway.
