    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Whirlpool GSF26C4EXW Refrigerator service manual requested, disassembly instructions for controls would be especially helpful.
Pulled a wire loose for the optics and need help accessing the workings of the freezer door. Thanks! The panel doesn't give itself away like the older models...
  • mlobermayr
Thank you, Master Samurai!
These are indeed what will alleviate ice troubles, however, unfortunately, in a misguided wrestling match with the fill tube and heater, I believe I have pulled loose a wire that connects to a board behind the user interface. The optics are now lifeless and the maker, iceless. Before, the problem was simply that the ice maker was reported to fill twice with every harvest and spill water on the floor--something I've never seen. Anyhow, instructions on how to non-destructively remove the user interface from the freezer door would be kindly appreciated, and/or any other wisdom on this matter...
Good day!
M.
Did you download and read both the service bulletins I posted for you?
