Service Manual Request for a 4 burner gas  kitchenaid cooktop mod# KGCT305BAL0 ser# xg4101046. im having a hard time figuring out how to open the unit up i have tried using the 5 burner MODEL KGCT366E service manual #4317225 butt they are not same. thank you
this cook top does not have screws in the burners, see attached.  so it looked like the bottom would be the access point but that does not come off either. it looks like the base is glued to glass top. if service manual is not available,  any suggestions I would appreciate. thank you
attached pic
this cook top dos not have screws in burner. job aid 4317256 dos have screws. access is not from bottom, glass top so cannot hit burner top to free it to turn. unsure how to grab burner to turn it. afraid if i do get it to turn im going to twist gas lines. i hope there is a job aid for this mod# KGCT305BAL0 ser# xg4101046. thank you
I've ran into a couple that seemed to be glued. Idk if they were or if the hat just melted the seals. I used my razor knife to free the top but be careful not to brake it they break easily. Almost all the parts inside that thing are no longer available I would take that into consideration before I wasted a lot of time on it.
i wasted a lot of time on this one 25 min just to remove bottom.  the thing was very corroded together, leaving me to believe at first that the bottom did not come off. afraid of busting the glass top i used a plastic tool. and yup parts are on a 2 week back order. thank you
