Looking for a NLA circuit board for a Goodman PCB036100-1
Good Morning.
I don't do HVAC work. I have a friend who's circuit board went out on the above unit. They were told the circuit board #B18099-11 22488 is NLA.
So my questions is:
1. Is there a replacement/comparable board?
2.Do you know a source for NLA Goodman parts?
3. Can you recommend somebody that work/rebuild Goodman circuit board?
4. Time to go shopping? :whistling:
Thanks for any help you can provide.
Bruce
Here you go:
http://www.myhvacparts.com/store/goodman-B1809911-control-board.php
https://nativesupplycompany.com/b1809911-goodman-honeywell-furnace-control-board-b1809911s-goodman
http://goodmanrepairparts.com/goodman-amana-furnace-control-board-b180911s/
According to this site
http://datasheets.globalspec.com/ds/4770/BestBuyHeatingandAirConditioning/D744EF01-46BD-44CE-9E2A-B775ED405F0A
this replaces yours and some other part numbers, one being ST9120D3009
If you search for ST9120D3009 on Ebay you should be able to source a compatible replacement like a universal
ST9120U1011
Searching the above part# you should find some suppliers to talk to that will let you know if this would be a compatible replacement if you can't figure it out for yourself what the original board is spec'ed for as to operating characteristics.
Here's a spec sheet for the ST9120U1011
https://customer.honeywell.com/resources/techlit/TechLitDocuments/63-0000s/63-9570.pdf
  • Like 2
You da man Willie
Thank you very much Willie!
Bruce
