Kitchen aid LP conversion instructions Mod# kgcu407vss01
I need the LP conversion instructions for this kitchen aid cook top. Mod# kgcu407vss01.
Thanks My Brothas!!!
  • applianceman97
having a tough time with this one. Do you have the part number for the perversion kit?  I'll try looking it up thata way.
Part # W10393255. I'm still looking through all my sources. No luck yet.
Stil can't find anything on this one. I think you'll need to use a low pressure conversion chart to select the correct LP orifice, like this one for low pressure applications (like gas cooktops):
The wrinkle is that the spuds will have a bore number stamped on them instead of an actual diameter. Like a gauge number for wires, bore numbers work the same way-- the larger the bore number, the smaller the drilled diameter. I've not found a conversion table listing bore numbers. Maybe someone else has one they can post.
