    • 15 February 2025 03:00 PM Until 04:00 PM
      Returning guest presenter Aaron Wilson is back for another exciting discussion. This time, we'll be talking about...
      The Science of CYA: How to Keep the Customer Safe, Document Your Work, and Not Get Sued
      We take on a lot of liability as appliance repair techs, and that can get us into sticky situations whether we've done anything wrong or not. Aaron will be teaching us all about how to navigate this side of the trade.
      We'll start by going over a tragic, real-world case study where a sloppy installation had lethal results, analyzing exactly how the installer's negligence caused this. From there, our scope will expand to what kind of safety precautions we should implement in our own work, both for the customer's sake and for our own.
      But even if you do everything perfectly, there's still the famous "technician witch hunt." Well, we'll also talk about how to deal with that by thoroughly documenting your work and putting yourself beyond legal reproach.
      A little about our guest, Aaron Wilson:
      Aaron has been in the appliance repair trade for about 15 years, starting out by doing installations before moving on to bigger and better things. He worked for C&W Services as a Sub-Zero authorized servicer for a time and thereafter joined Mr. Appliance of Highland Park in the Dallas area, where he worked for years as the lead technician and field service manager. These days, he's making sure that all the appliances of everyone's favorite fried chicken place are in tip-top shape as the Quality and Performance Consultant for the southwest branch of Chick-fil-A. In addition, he has taught many classes on refrigeration repair and advanced diagnostics, during which time he also developed training material for the soft skills side of things, which he is delighted to share with you. On top of all that he's a certified graduate of the Master Samurai Tech Academy, so he knows his stuff!
      When: Saturday, February 15 @10:00 AM Eastern Time.
KITCHENAID Side-by-side Refrigerator Model: KSRS27IHBL02
Requesting service manual for KITCHENAID Side-by-side Refrigerator
Model: KSRS27IHBL02
Did you try truncated searching using "Ksrs27*"... how bout widening the search to Ksrs2*? Find anything compatible? If you did not find anything compatible in the dl section, did you try truncated searching the entire site or specifically the Manual Request forum using "Ksrs27*" first then widening? Is what you find sufficiently compatible?
Searching in this manner can be very fruitful.... you may find tech sheets that are for a different size.. ie 25 cuft vs 27 cuft but everything else is the same... check it out... Secondly, by searching the entire site, you may find someone has requested a manual for a similar model and may point you to something you did not locate in the dl section. Also, by searching the site, you may just run across someone asking questions that may pertain to your issue.
Did you search " Kitchenaid SxS" in the dl section as well and checked out those manuals for compatibility? Sometimes things have been uploaded that may not specifically list individual model numbers
Find anything compatible? Let us know.
Edited by DurhamAppliance
