    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Need service manual for diagnostics and wiring diagram.
There appears to be a manual or a compatible manual in the download section. We ask our members to check the download section prior to requesting technical documents. If you have not already done so, make sure to watch the screencast entitled "searching for technical documents" found here :http://appliantology.org/topic/51337-getting-started-at-appliantology/. Pay close attention to the section discussing truncated and wildcard searches.
Also don't forget to search the forums as you may find topics that may point you to a compatible technical document file or you may even find topics that address your specific issues.
If you have already searched and have been unsuccessful in locating a compatible technical document, please let us know. Many times a manufacturer will not list all the models covered by a manual and sometimes may only list the model family. Therefore, it may be difficult for us to determine if your model is covered or not unless we look at the document, pull a parts schematic on your model and a listed model to see if they match. You are in a much better position to do this in a timely manner as you should already be familiar, to some extent, with your model's layout.
Thanks!
Edited by DurhamAppliance
