Frigidaire Mod FRA182MT2 Themostat engagement issue
I have a two year old Frigidaire 220V window AC unit.  The Tstat  operation is getting progressively worse.
Since I purchased it, it has never engaged the compressor earlier than about "4:00 or 4:30" on the knob position.  End of travel is around "5:00"
I have found that in order to get the compressor to turn on, I have to put the Tstat knob almost all the way clockwise to the stop.  Naturally, the cooler the ambient temp, the further I have to turn it to get it to switch the compressor on.  I am pretty sure it's getting worse as time goes on.
Last night it was to the point where I had to use a hair dryer for 20-30 seconds on the Tstat capillary sensor/bulb to get the compressor to turn on. Once it was on, it stayed on long enough to cool the room down.
I am in the 2-5 year warranty period, but I think that only covers the sealed parts of the system.  I don't think it covers the tstat.
Is there any kind of adjustment on the Tstat, or can I reposition the sensor bulb/tube to get better performance?
Or is my only recourse to get a new tstat and "hope" it fixes the issue?
Thanks...
  • Replies 6
  • applianceman18007260692
  • pjw73nh
  • BryanS
  • leamy
I'd say maybe there is something wrong the switch, but I have no idea. I don't even see a thermostat just sensors. One appears to be a defrost sensor. That's going off of your model with a 0 at the end. Could be wrong schematic
I would replace the sensor before thermostat. Unplug the sensor from the board and clean the contacts. Might just be corrosion.
Tnx for the quick replies.  This is what I found under the "parts" listing:
Part number: 5304476897
I have not had the unit apart yet.  it appears to be in the temp control itself as once I heat the tube up with the hair dryer, I can "feel" the detent/click in the knob itself when it "makes".
Brian, can you point me to the schematic?  Tnx.
I tried looking up a manual for it based on the model number, but it comes up with a model that has a digital display and panel.  My unit has no display and two mechanical knobs. One for temp and one for fan/cool -LO-Med-High.
It was on searspartsdirect.com under the parts breakdown. I looked under your model that ended in 0.
replacing the tstat would be the next step here.
the tstat bellows internally is sticking. so it take s longer for the pressure change
within the stat to bump the contacts close.
there is a setting screw on the front of the tstat but since there is a mechanical problem
with it your just going to end with a uncalibrated thermastat
try looking up the part using the number off of the casing you may find it cheaper that way.
If it has a sensor it be an electronic beast I am thinking. They stopped putting mercury bulb parts on ac's long ago.
