Maytag Commercial Washer F/L (MHN30PNCGW) programming
I have a client that has this washer and dryer.  I live in Costa Rica and he bought it here.  He can't get the service people where he bought it to come and help him, they say they don't know how to program it.  It apparently comes with a set program.  He wants to lower the drying time.  I have never seen one of these washers and would like some help on this.  If anyone has any experience with this model washer and could maybe lead me to a tech manual or something.  I can't find any thing on it in downloads and should probably post for a manual but thought I'd see if anyone has worked on one of these.  Any help is appreciated.
thanks
Doc
  • Replies 6
  • electro_doc
  • certified tech group 51
  • applianceman97
  • MrAdvantage
remove the lower panel, there should be a tech sheet with all of the info to program the options of your choice plus change the amount accepted to wash......It also has the diagnostic tests and trouble shooting guide......Instead of lowering the dry time, increase the amount charged.. :bunny: .....Keep a drain pump handy , they plug up fast and get cranky when they start to wear down  /out....Slow drain problems...........
Thanks, this one has not been set up to charge money, it is in a hotel.  So far as I know it is running fine its just that the maids put in two or three towells and it runs the same amount of time.  The owner wants it set for half the time and if need be they can run it twice.  Thanks for the tip, I'll check that out.
Doc
Moved to commercial appliance forum.
Didn't know there was such a thing.
Doc
  • 1 year later...
Having a tough time entering the wash amount, model #MHN30PDBW00 setting the wash price... I see the values where 3 xx 4 xx where 3 is dollars and 4 is cents, I've spent hours On this. F20 error, I replaced hot valve, but should I be looking for a drain, improper drain?!
F20 error code
Thefirstlevelofpressureswitchisnottrippedafter 6minutesand/orthesecondlevelofpressureswitch isnotreached.NOTE:Themessage“loH20”will appearbeforetheF20errorisdisplayed,andthewasher maytry3timesbeforethefailurecodeisactivated. Possible Causes –Nowatertowasher;faucet(s)turnedoff. –Defectivehotand/orcoldvalve(s). –Pluggedorkinkedinlethosesorvalves. –Pressureswitchorpressureswitchhose damaged,kinked,ordisconnected. –ElectricalconnectionfromCCU(PR6)topressure switchdamaged. –Drainhoseforceddownintostandpipe>6"(152mm). –Blockedinletfromdispensertotub. Procedure
1.Clearerrorcode.
2.Unplugwasherordisconnectpower.
3.Checkincomingwaterpressureatfaucet.
4.Checkinlethosesforpossibleleaks.
5.Makesurepressureswitchhoseisingoodcondition andproperlyconnectedtotubandpressureswitch.
6.Verifythatwaterisnotrunningoutofthedrainhose (siphoning)asitisfilling.
7.Performcontinuitytestonwireharnessconnections fromCCUtoinletvalves(VCH7andDI6),andto pressureswitch(PR6).
8.Checkinletvalvesbyrunningadiagnostictest;if waterfillstooslowly,replacetheappropriateinletvalve.
9.Checkthatthepumpisnotrunningwhilethe washerisfilling.
10.Verifypressureswitchoperationbyaccessing HelpModewhilerunningapaidcycle(seeHelp ModeSymbolsandElements,page13).
