thank you
Service Matters doesn't pull anything up on this one. You'll need to cross it over to a comparable Whirlpool OEM model number using a key part (such as the CCU or motor) on APP and then looking in the compatible models list at the bottom of the parts page. Then post a request for that OEM model and I can probably find something on it.
OK ill do that. I appreciate it, this one has been beating me up finding info. thank you,
that was grate advice, i searched sears whirlpool washer model list. walked thru them till i had a mach. model GHW9100LQ0 it has the same control & motor part numbers. i have service manual #8178076
THANKS again i had been looking for days.
  • Thanks 1
Way to go, buddy-row! Rock on!  :rocker:
