I searched the download area no luck ,,, thanks
Edited by yearclap
There appears to be a manual or a compatible manual in the download section. We ask our members to check the download section prior to requesting technical documents. If you have not already done so, make sure to watch the screencast entitled "searching for technical documents" found here :http://appliantology.org/topic/51337-getting-started-at-appliantology/. Pay close attention to the section discussing truncated and wildcard searches.
Also don't forget to search the forums as you may find topics that may point you to a compatible technical document file or you may even find topics that address your specific issues.
If you have already searched using the aforementioned techniques and have been unsuccessful in locating a compatible technical document, please let us know. Many times a manufacturer will not list all the models covered by a manual and sometimes may only list the model family. Therefore, it may be difficult for us to determine if you model is covered or not unless we look at the document, pull a parts schematic on your model and a listed model to see if they match. You are in a much better position to do this in a timely manner as you should already be familiar, to some extent, with your model's layout.
Thanks!
I found a tech sheet for it , but it didn't show diagram of parts location and removal ,, thank you
the tech sheets simply updates a standard job aid.... if you searched for "maytag bottom mount" you would have found this manualhttp://appliantology.org/files/file/306-maytag-amana-jenn-air-fridge-bottom-mount/
Also there are videos in the video classroom that show how to disassemble the freezer "rack and pinion" drawer as well as how to access the mainboard (jazz or utah version). All of this, however, is in the manual
I'll be more savvy next time, thank you
no problem.... just a learning curve but you apparently are a fast learner ... btw if you have any specific questions, post them in the kitchen forum... many of us are very familiar with this style
Edited by DurhamAppliance
You're awesome,  thank you!
