I dont know if my searching skills suck, but I couldnt find this one.
I know its a Samsung, and I have a lot of samsung manuals,
so if someone knows what model samsung this is, thatd be great!
time to improve your search skills bro Tone.... this manual is too easy to find in the download section using truncated/wildcard searching especially for an old hat like you... so gonna paste my normal spiel usually used for newbies....
There appears to be a manual or a compatible manual in the download section. We ask our members to check the download section prior to requesting technical documents. If you have not already done so, make sure to watch the screencast entitled "searching for technical documents" found here :http://appliantology.org/topic/51337-getting-started-at-appliantology/. Pay close attention to the section discussing truncated and wildcard searches.
You can also simply search the name of thr manufacturer and type of appliance if you have no luck using other search techniques.. for example "LG French Door" thdn scroll through the results.
Also don't forget to search the forums as you may find topics that may point you to a compatible technical document file or you may even find topics that address your specific issues.
If you have already searched and have been unsuccessful in locating a compatible technical document, please let us know. Many times a manufacturer will not list all the models covered by a manual and sometimes may only list the model family. Therefore, it may be difficult for us to determine if you model is covered or not unless we look at the document, pull a parts schematic on your model and a listed model to see if they match. You are in a much better position to do this in a timely manner as you should already be familiar, to some extent, with your model's layout.
Thanks!
Yea, I'll have to check out how to do it again, I did both exact model number and wildcard and absolutely nothing came up for me, this is the second time this has happened and I was told that the manual is already available.
Thanks.
well, I re-watched the video, tried both ways again, and nothing is popping up at all. I've checked the forums and downloads, nothing.
I took screen shots, but I'll have to post later.
I do normally find a lot of manuals, so it seems kinda strange, that I cant find this one, since it's so easy to find.
ok... hint ... search for "Pfs*"
and to make you really question yourself (cause I am... lol!) simply search for what you know.... like "GE Samsung"
So whatcha find?
  • Like 2
Got it bossman!
I was being way too specific...
very simple... if too specific results in no info, then become less specific.... continue to reduce specificity until hopefully the info you need comes up.... isn't that covered in Samurai's video I linked?
Yea, he mentioned it, but I gotta pretty thick dome, so it didnt penetrate.
I just over thought being specific was important, but I see the light now!
