Looking for a parts breakdown ... and service manual if anyone has it.
I got nuttin' on this one, Strath. Maybe one of the other Brethren can bail us out.
Is there a Month/Year built on the Mod/Ser tag?
If so and it is in the 1990's time frame this might help you.
I just worked on an older Kenmore (Apr 1992) one of these: Model# 417.99170810, style with pump on top of motor.
That model number looks like one of the older ones, before pump on top of motor.  Probably the style with pump under motor that you have to remove pump to change belt.
EDITED TO ADD: you might be in luck - did a google search and found this - maybe one of these model numbers will find yours - Part# 5303211162 Console end cap used on your model is used on below list of models and the year of the parts diagram that showed the picture was 1993, so my above Kenmore model might be of help also.
5303211162 Part Number: 5303211162 Description: END CAP,WLC271W1 Your Price: $ 28.49 Line Code: FRG Edited by Budget Appliance Repair
Thanks guys - I did not find my exact model, but I did find a stand alone washer that had the same components as the washer part of the stacker = model WWX645RET1.
Budget: looks like some of those models you provided are the same stacker.  Thanks!
