Wanted: Service manual that covers this GE samsung built PFSS6SKXBSS
Patricio! You didn't do a truncated wildcard search for this manual in the download or open forums?? You mean you didn't even do a simple search of the download forum for Samsung GE??
I guess I have to paste the info normally reserved for rookies or lazy techs. You certainly aint no rookie... so don't tell me you've become a lazy tech! I can't believe that...so maybe you should turn in your stripes and be considered a rookie again... then the following info reserved for rookies would be for you...
There appears to be a manual or a compatible manual in the download section. We ask our members to check the download section prior to requesting technical documents. If you have not already done so, make sure to watch the screencast entitled "searching for technical documents" found here :http://appliantology.org/topic/51337-getting-started-at-appliantology/. Pay close attention to the section discussing truncated and wildcard searches.
Also don't forget to search the forums as you may find topics that may point you to a compatible technical document file or you may even find topics that address your specific issues.
If you have already searched and have been unsuccessful in locating a compatible technical document, please let us know. Many times a manufacturer will not list all the models covered by a manual and sometimes may only list the model family. Therefore, it may be difficult for us to determine if you model is covered or not unless we look at the document, pull a parts schematic on your model and a listed model to see if they match. You are in a much better position to do this in a timely manner as you should already be familiar, to some extent, with your model's layout.
Thanks! .
Edited by DurhamAppliance
Durham there is not a manual for A PFSS6...S  Found a multi manual for a several different models including a PFSS6...P
My question is has anybody come across a model with the S.   Sometimes the different models are different.
Just maybe somebody other than you has come across this manual & can share kindness rather than bitterness.
Edited by Patricio
Did you even look at the manual? Did you check to see if it is compatible? So you want us to do that for you? Did you mention in your initial request that you even checked the GE Samsung manual in the dl section? It's not bitterness.. it's disbelief
