    • 15 February 2025 03:00 PM Until 04:00 PM
      Returning guest presenter Aaron Wilson is back for another exciting discussion. This time, we'll be talking about...
      The Science of CYA: How to Keep the Customer Safe, Document Your Work, and Not Get Sued
      We take on a lot of liability as appliance repair techs, and that can get us into sticky situations whether we've done anything wrong or not. Aaron will be teaching us all about how to navigate this side of the trade.
      We'll start by going over a tragic, real-world case study where a sloppy installation had lethal results, analyzing exactly how the installer's negligence caused this. From there, our scope will expand to what kind of safety precautions we should implement in our own work, both for the customer's sake and for our own.
      But even if you do everything perfectly, there's still the famous "technician witch hunt." Well, we'll also talk about how to deal with that by thoroughly documenting your work and putting yourself beyond legal reproach.
      A little about our guest, Aaron Wilson:
      Aaron has been in the appliance repair trade for about 15 years, starting out by doing installations before moving on to bigger and better things. He worked for C&W Services as a Sub-Zero authorized servicer for a time and thereafter joined Mr. Appliance of Highland Park in the Dallas area, where he worked for years as the lead technician and field service manager. These days, he's making sure that all the appliances of everyone's favorite fried chicken place are in tip-top shape as the Quality and Performance Consultant for the southwest branch of Chick-fil-A. In addition, he has taught many classes on refrigeration repair and advanced diagnostics, during which time he also developed training material for the soft skills side of things, which he is delighted to share with you. On top of all that he's a certified graduate of the Master Samurai Tech Academy, so he knows his stuff!
      When: Saturday, February 15 @10:00 AM Eastern Time.
Closest thing to this manual I can find in down load is LDF8072ST.   Will this work?     LGtechassist is showing me part not available in tech publication search or am I looking in wrong direction.
  • Replies 4
  • DurhamAppliance
  • Patricio
  • B4UTRUST
i got a "no data found" as well.
Whether the other manual would work depends on if they use the same or similar board, interface and body...
compare the two models......let us know what you find out.
Back online after another long day.  the main board is off by 2 numbers at the end, same with pcb board.  parts diagram has same diagram part numbers as well as same drawings.   So in your experience do you recon the that the manual is the same or is it just similar.   I must be OCD wanting everything to match up exactly  correct.   I would dare to say that they will work,  Would not be  happy if I show up with wrong manual.   so I ask.
experiences are different with different machines and with different manufactures.  I suggest you call LG and advise them the manual isn't on tech assist....they may be able to provide you with guidance as to whether the manual you have is useful with your model number
Manual
Patricio, there's a link to the manual once an admin approves it. Also sent you a link on to a dropbox share of it. Let me know if either of those don't work and I can email it to you directly if need be.
