Samsung refer RSG257aa**
Need the service manual to access the Ice dispenser door...........door is loose and flaps in the wind.....Do not need the fast track/diagnostics......Just how to get the dispenser display panel off............Found two release tabs hidden under the panel but control panel will not remove with out a very large  2x4 and a crow bar  :woot:  ......Someone else way back in Oct of 2013? asked for the same service manual for the same repair, not one single response/post....
  • Replies 4
  • certified tech group 51
  • DurhamAppliance
  • Econo Appliance
and...
I think I may have done this only once so I can't offer much practical help.
Edited by DurhamAppliance
Yup, i removed the screw, released the tabs, but the top of the stainless steel panel would not release....pulled a bit but it would not let go........guess I gotta pull harder....Thanks Durham for the info......I ordered the ice route assy, now I gotta get it apart to 'Fix-it'......
  • 6 years later...
Doing the same model at the moment.  WOW the top clips are in there tight!!! Thought i was gonna snap the panel in half, and it popped out.
