Would like to know how to put unit into a manual defrost, and if, any diagnostics are available through dispenser. Thanks
Do a standard wildcard/truncated search of the library and several compatible tech sheets will come up. Tech sheet covers this model (called a dispenser model with very basic temp controls at the dispenser) and encoder models (non dispenser models ie using knobs instead of dispenser temp control) . For full manual download standard gss encoder model manual. No diagnostics at the dispenser controls. Diagnostics at the board or with GE test kit.
also never leave home without this http://appliantology.org/blog/1/entry-730-ge-refrigerator-repair-survival-kit/
Edited by DurhamAppliance
Thanks for the information, it was exactly what I needed.
