KSRS25FGSS11 Job Aid/full manual needed
I have been plagued with Kitchenaid fridge repairs lately and I see more on my upcoming schedule.. ugh! . This model is a bit different from the others. I have the tech sheet for it but none of the SxS jobaids in the dl section are compatible.
This model has the slide contols for freezer and fridge in the ff section and from the outside the contols look exactly like the standard whirlpools with the timer/adc on the right and has that cold control with the long capillary tube that fails often.
But inside the controls, both freezer and fridge have cold controls (each has a ground and three spade connectors, one connector labeled "cut in" and another marked "cut out"). The fridge control operates the damper and evap fan and the freezer thermostat controls the compressor. If this set-up sounds familiar and you have a full manual or jobaid, I will forever be thankful!
