JGB918SEK4SS GE Double oven range
IgorY
Hi! I am looking for a tech sheet or a manual for GE doublr oven range JGB918SEK4SS. Customer complains that is is doesnt ignite properly- both cooktop and oven. Thank You!
  • Replies 1
  • IgorY
