HWT121QN1102 Huebsch Repair Manuals etc.
Hi
I was just given about a dozen of these Huebsch top load coin op washers. Free.  Also a couple Econowash) I've never worked on these and would appreciate any material anyone may have on these. Parts breakdown diagram? General repair manual? Whatever would help.
I also got as part of the lot, a residential Huebsch top loader Md #LWZ22NW that's in nice condition except I believe it has a bearing issue (typical growling sound in spin)
I downloaded everything I could find on this site but it all relates to the extractors not the top loads
Anyway, Hope someone here can help out.
 I can't even figure out how to get the agitator off of the residential washer yet.
  • Replies 4
  • Garpy
  • Budget Appliance Repair
  • Adirondack Bob
  • Scottthewolf
www.pwslaundry.com
I download a lot of the commercial laundry models from them.
Hi Scott
Thank you. I've taken a quick look and found a few manuals on the top load Huebsch Washers so far. I can't find a manual for this exact one relating to how to remove the agitator as my ones don't seem to have a nut like the ones in the manuals.
Either way, I'm now way further ahead.
Thanks again.
Agitator should come off like GE does.  Need to work fingers under agitator on both sides and pull up.
If it doesn't want come loose you can loop a rope under two sides of the agitator and over a 2x4 and use it as a lever to pull agitator.
