RiverviewAppliance
Hey i need the tech sheet and any other relevant information for this model, thanks.
  • Replies 1
  • RiverviewAppliance
Couldn't find a service manual on this one but here's the procedure for putting the control into manual test mode:
Service Information
ID# 4431   :   Front Load Washer: Test Mode: WM1814CW / WM1812CW / WM2010CW / WM1815CS / WD-90286BD
Part Location Part Description
Front Load Washer: Test Mode: WM1814CW / WM1812CW / WM2010CW / WM1815CS / WD-90286BD - Article 4431
The laundry washer must be empty and turned OFF.
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
While continuing to hold spin speed and soil level, also press the POWER BUTTON.The buzzer will sound twice.
Unit powers on.Release first three buttons.
Press START/PAUSE button once to enter test mode.
CAUTION! Test mode procedure change.
Push the START/PAUSE button ONLY ONCE at High Speed Spin.
When the drum is rotating at high rpm, never push the Start/Pause button repeatedly. Unrepairable damage to the main board could result.
Number of times
Start/Pause button is pressed Check Point Display Status
None Turns on all lamps and locks the door
1 time Tumble clockwise rpm (40~50)
2 times Low speed spin rpm
3 times High speed spin rpm
4 times DO NOT proceed until spin has STOPPED and Inlet valve for prewash turns on Water level frequency (25~65)
5 times Inlet valve for main wash turns on Water level frequency (25~65)
6 times Inlet valve for hot water turns on Water level frequency (25~65)
7 times Inlet valve for bleach turns on Water level frequency (25~65)
8 times Tumble counter clockwise rpm (40~50)
9 times Water temperature (thermistor) Water temperature [C°]
10 times Drain pump turns on Water level frequency (25~65)
11 times Powers off. Door unlocks All lamps turn off
