Requesting tech sheet/manual for Magic Chef Gas Range MOD: 6498vvv
Danka
  • Replies 1
  • Techonamission
Strikeout on the tech sheet/manual. But I do have a list of fault codes for this old dawg:
MAGIC CHEF
Range/Stove/Oven Fault Codes
Failure
Code Condition Check/Repair
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2 Oven too hot Check oven temperature sensor
F3 F4 Open or shorted oven temperature sensor Replace
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
F6 Missing AC signal Replace clock assembly (also called the ERC)
F7 Function key shorted Replace touch pad
F8 Analog/Digital converter Replace clock assembly (also called the ERC)
F9 Door latch Check door lock circuit
F10 Function key stuck Replace touch pad
