Bosch Dishwasher SGS09A08GB/11 limescale deposits
Hi there,
I'm back after some time with yet another issue with my 10y old Bosch dishwasher.
Few days ago I run several cycles in a row and found the inside of the dishwasher - and what was inside it - covered in what I believe was limescale. I sprayed some limescale remover on a small section of the door, left it there a few minutes and wiped the fluid and the metal was shiny again - this is why I believe it was limescale.
I then run a dishwasher cleaner and all went sparkly again.
Yesterday I had a similar issue after a quick rinse cycle. Not so sever as I only run one cycle.
My water is pretty hard, salt is set at maximum - always been. There is salt in the reservoir (Finish salt). The dishwasher worked fine for a few cycles after I run the cleaner so it seems that things are still somehow working inside.
Is there anything I can do? I believe some salt is dispensed at every cycle to regenerate the resins, maybe the dispenser is intermittent?
This is a glass out of the dishwasher (it is not 'worn out', it should be very shiny)
https://www.dropbox.com/s/phfsyyzjwdas9ga/2015-12-07%2019.24.20.jpg?dl=0
This is the door
https://www.dropbox.com/s/hvhjjvd2jy3zeya/2015-12-07%2019.24.39.jpg?dl=0
Any help appreciated!
Thanks!
Tony
Good pics, common problem. Some questions:
1. What kind of detergent are you using?
2. Are you using rinse aid?
3. Are you pre-rinsing the dishes before you run them in the dishwasher?
Homework assignment:
Dip a cloudy glass halfway into a bowl of vinegar for a couple of minutes. Rinse, dry and post another photo of the glass.
Hi,
Thanks for your reply.
1. Finish powder. No "all in one".
2. Yes
3. No
When I have another cloudy run I'll run the vinegar test. However I did spray some limescale remover on a small area of the door after it happened. With no cleaning action it came up shiny after just a minute, just wiping away the limescale remover. This is why I feel it's limescale and not salt.
  • 2 weeks later...
Hi
This hasn't happened again.
I remember I've seen this before, at the office.
What is causing that? How is it possible that one wash cycle is fine and another is not?
  • 3 weeks later...
Hi there,
It's happened again today even though it didn't leave much staines on the dishes.
Picture of the dishwasher door.
Then I poured a little vinegar on the door, left it there for a while, then washed with softened water - so not to leave residues.
Result is below. It's indeed limescale.
Can someone please tell me why this is happening randomly? Repair Man, any help? You teased me and then disappeared! :)
