Need manual for SHV68M03UC/46
The info in the generic Sears manual for SHV68 doesn't match what actually exists on the machine (of course, Bosch....sheesh).  The machine only has a schematic with it, not test mode or fault code info.
According to Bosch, any of these three service manual PUBs may apply to this model:
58300000125963
58300000133621
58300000148618
Search the downloads with each of these THREE PUB numbers and you'll find them there. Compare with your specific model and see which is the one you need.
Sorry, best I can narrow it down for you but that's Bosch documentation fer ya!
Thanks man, I'll check it out.
I've just confirmed that the publications in the above post apply to the model in the original post at least as far as service mode entry procedure and component test cycles go.
Thanks for the update. That wasn't even one of the pub numbers called out by the Bosch site for this model. Freakin' Bosch.
