I have seen the service bulliten about the "leaking" mushroom float assembly. I need the service manual. Some Von-A-Hole Has removed it from the washer. Think I can get a copy if available?
Ms Ann
  • MsAnn
I can't believe it. You are the ninja Santa!!! Yes sir reeeee!
