the electricity went out a while back, gas oven wouldn't come on.  Finally found online manual, talked about setting digital clock, did that.  Since then, the oven was finicky as far as if it came on or not.  Friday it would not come on at all.  The stovetop works though.  Do not smell gas when putting oven on.  Can't figure out where the pilot light is & manual doesn't say where it is.
Lisa S
What is the model number of the range. The number posted in the title is not the model number.
Look around the pot and pan drawer for the #
Sorry about that.  The model # is FFGF3017LWE
your stove has a glowbar igniter , it is always the first thing I check on any gas oven ,  most of the time it is the problem .
Oven igniter Part number: 316489402
Lisa Searles
the oven igniter was bad, changed it, but oven still will not come on. Any other ideas?
