GE Model: TFX24ELM SideXSide Compressor on constantly to cold in Fresh Food compartment.
FastEddie746
GE Model: TFX24ELM SideXSide.  Setting of "A" and "1" Compressor on constantly.  Freezer -5 degrees, 25 degrees in Fresh Food compartment.  It may stop once a day for 5 minutes.  This is what I have tried so far.
Diagnostic Test is NORMAL.
I replaced fresh food gasket and cleaned the coils underneath the unit.
I replaced temperature control thermostat - no change (old thermostat tested OK later)
Pin 10 (cube relay drive) of electronic control system read .74v should be (13-20Vdc)  In looking at 9 pin connector I saw green corrosion growing across top of connector pins.  Scrapped off and now I have 14 Volts at pin 10.
Meat control ASM was loose siliconed back into place. - Set closed.
No ice on condensor coils.
What else can be the cause of the constant compressor running.  It can't be normal.
ED
  • Replies 4
  • FastEddie746
Explain what these settings correspond to, eg., Freezer coldest, Freezer warmer, FF colder, etc.
Irrelevant to the problem you're reporting in this topic.
The electronic control has its own temperature sensor, and early style thermistor, connected between pins 1 and 5. The tech sheet lists temperature-resistance data for this sensor. You need to verify this sensor is in spec.
FastEddie746
Yes, sorry.
 Freezer Mechanical dial setting to "A"     (A) warmer to (E) coldest  ----- Actual freezer temp -6*F
Refrigerator Temperature control thermostat set to "1"   (1) warmer (9) coldest   -------- Actual refrigerator temp.  28*F
Spec. Thermister Readings:   90*F  37K     41K
                                                70*F 59K      55.2K
                                                55*F  87K     77.5K
                                                35*F  150K   135K
                                                 0*F   427*F    395K
So the thermister is off on the lower end.
                                                70*F 59K      55.2K
                                                55*F  87K     77.5K
                                                35*F  150K   135K
                                                 0*F   427*F    395K
I just gotta ask-- what was you methodology for changing the thermistor temperatures and then verifying what those temperatures actually were?
FastEddie746
I placed the thermister in a paper cup with 91 proof rubbing alcohol so it would not freeze.
The leads to my meter were attached to the thermister.  The freezer was at -20.  I pulled entire setup and connected to meter K ohms range.
I used a Robi infrared thermometer +-5% accuracy and waited for the temp threshold to take a  reading.  I assumed the surface and submerged thermister were the same temperature.
So you think replace the thermister?    ;0
Thanks ED
