Kenmore Elite Double Wall Oven Error Code
New Kenmore Elite Double Wall Oven
model #790.48443410
What does error code F029 (continuous beeping, "upper") mean?
How do you clear this error?
It comes up when power is first applied.
  • Reedman
The communication between the over user interface and the touch panel cannot be initiated.
1. Disconnect power to the unit, wait 30 seconds, then reapply power.
2. If fault returns, verify touch panel is connected (verify harness going to I2C1 or I2C2 connector) and is getting
power from the oven user interface.
3. Verify the unit has the proper oven user interface board and touch panel, based on the model number and
parts catalog.
4. If fault persists, replace the touch panel.
5. If fault persists, replace the oven user interface.
Tech Sheet:
Thank you very much!!!!
