I am in the "System Information" "More Information" diagnostic screen of a Jenn Air JJJW3830Ws00 double wall oven. I am reading the RPMs for both the upper and lower oven cooling fans. Does anyone know what the normal RPM range is for the UPPER oven cooling fan when it is running in the low speed mode and what the normal RPM range is for the LOWER oven cooling fan when it is running at low speed mode.. Looking for the same info for each when they are running in the high speed mode. Also what is the rpm "low speed" RPM threshold that triggers an oven UNDERSPEED error code for the fans when they are running in the low speed mode low speed and the threshold when they are running at high speed. Thanks.
  • Al
  • sethcoult
It all starts with posting a valid model number. Then we can pull the tech sheet and have a look.
BTW, you can verify you have a valid model number by plugging it in to http://repairclinic.com -- if the model number doesn't pull up, then you know the model number is bad. ;):)
OOPs, I was typing a bit to fast and did not check my entry. The correct model number is Jenn Air JJW3830WS00. Sorry about that.
  • 8 years later...
did you ever find the answer?
i have the same issue same number.
jennaire only gives info to their "authorized" techs. so no help there.
i replace the blower in april (dead) no 8 months later i am going back out. (F8E0).
the instructions say upper fan lower fan but there is only one fan....lol
