I need a service manual desperately. There is this crappy wiring diagram that I cannot even read. What I am looking for is service manual with those items included. Is there on available. I tried the search through forums and downloads numerous time and could not locate. I have never seen one of this put together like this. I need to do some disassembly work and testing. Can someone help please?
The only thing Service Matters has on this is the parts manual, which I've uploaded for you:
It is often very useful for disassembly help.
This is a problem with Kenmore-branded stuff-- they become an obstacle to finding the actual OEM tech docs. One work around is to cross the Kenmore model number over to the OEM equivalent using the patent-pending Brother Durham Method™ and then search for documentation on that OEM number:
Thank you!!!
I try to get the part number off of the part list which is a big help in finding the tech sheets.
Uploaded after approval
