I'm looking for the information on removing the control panel from this laundry center.  I downloaded the a manual that says it's for this model, but the control panel is above the dryer door.  My control panel is below the dryer door.  So if anybody can tell me how to get the control panel off of this machine Mod # LTE5243DQ3 without dynamite I would greatly appreciate it.
Wan
I uploaded the parts manual for you:
Note screw 15 on the control panel. Loosen these on each side (don't take them all the way out) and the control panel will lift up, unhook, and tilt forward from the top and hand down.
  • Thanks 1
Thank you!  I never seen this type of locking mechanism before.  Thanks for your help!!!
Wan
