kenmore elite 110 71082000 control panel won't come on
My dryer control panel won't come on, no lights, no start. I think it's the control board but not sure.
I have checked door switch, thermal fuse, and belt switch. I have voltage (120v)  from L1 to P1-1, P1-2, P1-3, P1-4.
Any suggestions would be appreciated.
  • 2 weeks later...
I installed a new control board and still no control panel.
If you have power at the main control and you already replaced main control with same results, then you need a new control panel. All you need for the display to work is the main board with proper voltage and the control panel properly connected with good wires.
On January 31, 2016 at 9:54 AM, johntech said:
new control panel
Part number: 8316669
