KitchenAid KIRD861HSS-1 Motor Arm Reattach
I have a KitchenAid downdraft vent KIRD861HSS-1. When I pressed the button to lower it, I heard a thud (like a metal part falling) and then the up and down mechanism stopped working properly (does not go all the way up). I removed the blower box to look inside and saw that the motor arm is unattached. I found the bolt and nut at the bottom of the casing. Problem is that I cannot figure out how to put the bolt back to where it sticks out of the front of the slide to reconnect the arm. There is not enough clearance to get it in there with the guide piece on the backside of the slide. Even when I push the slide all the way up by hand, I can't get the clearance. Any ideas?
  • Replies 0
  • SPozz
