unable to remove inner basket whp DD washer 110.26902690
Lorri Maxwell
I humbly request the benefit of the world-renowned collective wisdom here at 'appliantology' with the two following subjects:
Primus: Removal of inner basket. Today is the third in a row wasted in unsuccessful attempts to remove the inner basket from my (Whirlpool) direct drive washer model 110.26902690. I have:
poured -gallons- of boiling water in and around junction of transmission shaft /spin tube (where inner basket 'sits' atop drive block)
soaked (same) w/heavy duty degreaser 24hrs then flushed w/boiling water
soaked (same) w/ PB Blaster, rinse, repeat above steps
proved that, despite my reputation, I may not be capable of breaking everything I touch, including the 'seal' that seems to be gluing the inner basket to the drive block and shaft on my washer.
in short, I've tried everything I could think of as well as searching online for others w/same issue. Unfortunately, mine seems to be an extreme case.
Sensei(s), please help enlighten this desperate seeker!
.......(2nd issue when 1st is resolved, stay tuned/thank you!)
  • Replies 0
  • Lorri Maxwell
