rockhopper46038
Gentlemen, I could use some help. I have a pretty old Jenn-Air model# SVE47500b electric range that has not functioned properly for some time and I finally decided to try and fix it. The stovetop elements all work fine, but the front display is completely blank. Pressing the membrane buttons on the front results in "beeps" but nothing else. I did some research and ordered a relay control board (the small board on the back of the oven behind the stamped cover) but when I replaced that board it had no effect on the problem. I then replaced the clock board in the front of the unit and lo and behold I have a working display! However, when i pressed the "bake" button and input a temperature of 350 degrees (or really, any number), i almost immediately get an error code of "F5" and a continuous "beep" until I press "cancel" on the membrane keypad. Stove top elements still work fine, but oven doesn't heat up at all - I just get that error code.
Anything else I can try, or do i need to call in a repair technician?  I'm wasn't quite ready to replace the oven yet (was going to wait until i did a kitchen remodel) and while I can return the relay control board (the old one performs indistinguishably from the new one), keeping the clock board means I've got a little under $300 into this repair and unless I can fix it for less than about $500 total I think I might just be looking at a replacement oven...
rockhopper46038
Reading some of the other posts on the SVE47500b is it possible that I need to add a jumper between pin 5 and pin 15 on the new clock board? The "F5" code does reference some sort of "watchdog circuit disagreement"...
check/replace oven sensor
rockhopper46038
Just got this part and tried it without any luck. Still f5 fault code. It is possible that it took a little longer to fault out, because I saw the "preheat" words appear this time and I didn't think I saw those before, but in the end about 5-10 seconds after touching "bake" and inputting a value (350) I still get the beeping f5 fault.
Any other ideas?
richseattle56
I will upload the service manual to pot luck. Look for 16010191 SVD48600P Jenn Air Slide in Range.pdf
F5 error is a int. or defective oven sensor.
Ohm out sensor at control board. youll be looking for around 950-1000 ohms.
double check your connections
