Hello, I believe this is the correct model number.
Jason
did you search the download section?
Yes, I am aware of the process. I am not sure if D3251 is similar to other models. First time working on an ASKO.
We cannot tell who is and who isn't aware of the process so it would be in your best interest to include in your original post that you searched and could not find anything or unsure of what you found.. saves everybody time.
Now searching for your model number yields
but this is just a parts manual.. but the description does provide us a clue... "Type DW20.3" That's either what your model is called or it's so similar that it uses the same parts... So let's search for  "DW20"   or simply search for "Asko Dishwashers"  and scroll for DW20.3...
doing so we find this  service and training manual :
Looking at the  description it says this manual covers series 3000 dishwashers... ours is a 3251...pretty good chance it's your manual.  If you want to be 100 percent certain,  simply look up your interface on a parts site and compare with images in the manual.
Did that, just double checking.
Jason
Cool,  but this  thread can help others reading it to learn a few search techniques. So although we respond to you,  we are also providing info to a wider audience.
Edited by DurhamAppliance
