EWFLS70JSS Electrolux Wave Washer leaks
Mark MacDonald
Any ideas how to remedy this?
  • Mark MacDonald
  • 16345Ed
Mark MacDonald
I should have mentioned it leaks during the cycle.  Not a lot of water, but enough that it must be soaked up with a towel.
it leaks during the cycle?
what cycle?
there are so many places washers can leak you need to investigate.
Start at water source (hoses) and start checking for leak. You will have to take cabinet off the unit if the leak isn't in the hoses or hose connections.
With cabinet removed run washer and again check for source of leak.
Good luck!
