Requesting tech sheet for Whirlpool Gas Dryer MOD: LGR5636JQ0
Thanks Jas!
  • Techonamission
Dayyam, Brother 'cruz, seems like you're getting tech docs on mostly old stuff. Have you started working on any newer or high-end stuff yet?
Here's the wiring diagram for this dinosaur dryer, seen one, seen 'em all!
Most of the stuff I work on is 2-10 years old I'd say. I stay away from some high end brands like Bosch, Sub-Zero and Miele, mostly from bad experiences with the type of customers I get from those appliances. I realize that pretty much all dryer tech sheets are the same but if I dont have it when going out on a even a dinosaur, I can still run into trouble with tracing wires or wire color.  Better safe than sorry.
